1998 Oceanpro 200 VRO Question
G
Guest
Guest
I bought a new VRO Tank (w/ System Check) assembly for my 98 Ocean Pro 200.
I followed the instructions and everything went in fine, but there is a 2 wire and 2 -prong male Deutsch connector (black wire and black/tan wire) coming from the top of the VRO tank.
There's no female Deustch recepticle to hook it up on the motor, or my binnicle control (every Deustch connector is spoken for)
I pulled the panel on the port side of the motor where the control harness plugs in, and I have (2) 3 prong triangular Deutsch connectors and (2) 6 prong Deutsch connectors. but there is nothing on the power head to accommodate this 2 prong male connector from the VRO tank. (There is also a 2 wire connector below this panel (non Deutsch) that is described in the OMC tech Manual as a VRO "connection".
The directions for the tank say nothing about where this connects to, and even my 1998 OMC shop manual doesn't say where this 2 prong wire from the tank hooks up. The only thing I can can think of is if this tank is for a pre-96 motor.
Otherwise, does my origina (1998) harness on the motor sense the level in the VRO tank and not the separate lead wire off the tank.?
Any help is apprciated. Thanks!
flyingscott
If you have the old sensor cut the leads off and splice those onto the end the new sensor and connect to the old sensor connections. The tan wire is the sensor wire and black is ground. That sensor only measures the oil level in the tank.
dingbat
I replaced the tank on 1997 last year. Connector from tank plugged into harness. Under the black cover on the port side of the motor if I remenber correctly
daselbee
Don't cut ANY harnesses. You will find you do not need to.
The two wires in question are the low oil sensor wires. Black is ground, and tan/black is the actual sensor wire. When the oil is low in the tank, a switch in the tank shorts the two wires together. If you leave the plug disconnected, your "low oil" alarm will not work. Engine running will not be affected.
You will absolutely have a matching Deutsch connector somewhere on the port side of the engine. Keep looking.
G
Guest
Guest
Thanks for the replies Guys,
I didn't check the harness at the motor end, maybe its something I missed. there is no 2 prong female connection behind the black panel where the other Deutsch connectors are.
I will check again
flyingscott
Where did the old one plug in? And what plug is on the old tank sensor?
dingbat
I will check again
Let me know if you can't find it. I'll go out and check when I get home this evening
G
Guest
Guest
Thanks Ding!
I'm going to look for it again when I get home, Your 97 should be the exact same as my 98.
dingbat
It's a two pin connector. Black and brown wires. Bottom slot, behind cover.
the connectors are two deep. My connector was on top but having been replaced, I can't say that it wasn't behind before I pulled it to replace
G
Guest
Guest
Thanks Ding,
That may explain this mystery, I took the black panel cover off, but didn't pull the Deutsch connectors out, If the bottom connector are two deep, that explains why I wouldn't see it. I'll pull the bottom connector and see whats behind it.
