1998 Mercury 90HP Starter Engages Only Briefly
Oldsaltydog
I have done quite a bit of background research, but I have not found an answer to my particular starter problem yet. Especially when the outboard motor is cold, the starting gear will run up the shaft just fine, but it either will not turn the motor over or it will turn it for a second or two and drop back down again. After repeating this process two or three times, the motor will eventually start. The battery is new and it seems to be charged okay, but I have to admit that I have not checked out all the starting circuit connections yet. (But I have done tons of other repairs on this new purchase.) Any suggestions?
Oldsaltydog
Re: 1998 Mercury 90HP Starter Engages Only Briefly
The problem proved to be a Bendix gear caked with old gunky grease.
