baseballa51
Thread starter- Joined
- Jun 12, 2016
- 6
I feel like I'm beating a dead horse with all the posts I've read about timing and the proper procedure. I have ALL new ignition components, including plugs and wires with about 20 hours of run time. I have been battling running rough for a while, so much that I never take the boat out. When I attempt to enter base timing mode, nothing changes with the RPMs, and wants to stall out as I approach the proper timing mark while rotating distributor. It only runs well way out of spec on timing (~20-25 degrees BTDC at idle). Last week I troubleshooted again and noticed it was not advancing with RPM at all. I replaced the inexpensive ignition control module with a reputable manufacturer (Sierra) thinking that was the issue with the inability to accurately base time and not advancing. Well here we are and it's exactly the same symptoms. I have verified the schematic with my multimeter, tested components, followed instructions to a T. It has new fuel pump, rebuilt carb, filters, fuel water separator, basically everything that can be bolted to the engine has been replaced within 20 hrs of runtime. I've spent weeks researching and looking at hundreds of forum posts and countless videos. I am completely stumped. Any help at all is appreciated.
