Yup,someone said it could be power pack but the mechanic said crank the motor and tap the power pack with a screw driver and if the power pack is bad the motor will cut out, well ive done that and motor runs strong, only problem is it will not fire until you pull plug and ground to the motor, after it cranks up I can put the plug back in and hook back up plug wire and the motor will still crank, let it set for a few hours and it does it all over again
