1998 Johnson 115 died while running
JB96
Hey guys, It looks like theres a lot of wisdom on here so Im hoping someone will be able to point me in the right direction. I have a 98 model 115 Johnson V4. I bought it in October and its been a solid motor up until last week. I was running at about 4500 rpm and the motor just died. I went to restart it and the battery was very weak. I got it to turn over 3 or 4 times before it died. Up until this point it had been running normal for several hours and the previous day for 5-6 hours also. The battery is only about 3 months old and tests good. Another weird thing that happened was when I finally got home, I went and hit the key to just see if it would do anything. The motor very slowly turned over so turned the key back to off however the motor kept turning over. I had to disconnect the battery cables to get it to stop. So i replaced the ignition switch. After that Im assuming its an electrical issue. Im trying to figure out where I should start to look to find the problem. Any advise is much appreciated. Thanks!
Model # as there may be 2 different styles of 115 HP motors.-----Check the gear oil.----Take starter apart for inspection.
flyingscott
It sounds like your motor may have overheated. If you can ,do a compression and spark test. We also need the model # if that is a crossflow motor it may have broken a ring. I dont remember if they made a crossflow in 98 so need the model #.Could also be in the lower unit.
Yes the 98 was the last year of crossflow.----Have one myself.
JB96
Thanks for the quick replies. Unfortunately the model tag came off at some point before i purchased it and I'm not sure about the ignition system. The motor was pissing strong when it died so I don't believe it was running hot. It also has the buzzer that goes off if its hot. I changed the lower unit oil about a month ago and everything looked normal to me (oil wasn't burnt, no metal pieces that i noticed). Also, and this might not make a difference, but the prior owner had a mechanic remove the oil injection so its premix now. Ill check the starter and lower unit oil this evening and report back. Is there a way i could tell if it's crossfire ignition?
Does the motor have 2 carburetors with 2 barrels each and horizontal ?----Or does it have 4 carburetors that are vertical and 2 on each side of the motor ?------An open flywheel or one that is enclosed ?----Motor with an exposed flywheel is a CROSSFLOW motor.
JB96
The flywheel is open with 4 carbs in that format. So it is a crossflow.
Don't rush out and buy a new starter.----Take it apart for inspection and an ohm reading from commutator to the shaft.----Should read infinity.---------Is oil injection in service and checked to be working properly ?-----Compression test is in order too.
oldboat1
Check to insure the VRO harness was disconnected, and the oil input at the motor plugged. Use a 50:1 premix. +1 on a compression check.
Your regulator/rectifier may have gone out, possibly overheated.
JB96
Happy Fathers Day y'all. I did a compression test and it came back at just over 80 on all cylinders which seems really low to me. I messed around with it yesterday evening and it would start for a few seconds with starting fluid (I only did it twice because I know its bad for 2 strokes). Its also getting spark on all cylinders.
flyingscott
That compression is really low. If the motor is turning slow it will give low compression readings. Get a different gauge and try again if #s are the same take off the lower unit and test again. If #s are still the same check the starter out.
Remove a couple of bypass covers ( 6 wee bolts each ) and have a look at the pistons / rings.----Compression tester is out or you have problems.
interalian
If your motor kept cranking after you let the key go, that points to a fused/welded solenoid. If the contacts in the solenoid are burned that can give high resistance and cause slow cranking. Test by bypassing the two big terminals with an automotive style jumper cable, or go from battery + to the terminal with the red cable on the starter itself.
