Hey guys, It looks like theres a lot of wisdom on here so Im hoping someone will be able to point me in the right direction. I have a 98 model 115 Johnson V4. I bought it in October and its been a solid motor up until last week. I was running at about 4500 rpm and the motor just died. I went to restart it and the battery was very weak. I got it to turn over 3 or 4 times before it died. Up until this point it had been running normal for several hours and the previous day for 5-6 hours also. The battery is only about 3 months old and tests good. Another weird thing that happened was when I finally got home, I went and hit the key to just see if it would do anything. The motor very slowly turned over so turned the key back to off however the motor kept turning over. I had to disconnect the battery cables to get it to stop. So i replaced the ignition switch. After that Im assuming its an electrical issue. Im trying to figure out where I should start to look to find the problem. Any advise is much appreciated. Thanks!
