1998 force tilt and trim problems
chuck havens
i have a 1998 force 85 hp. i am having tilt and trim problems.i have no leaks but when i try to tilt up or trim down i just hear a clicking noise. i have replaced the relays with ones from a car and nothing changed. this has got me stopes out of the water . can someone help me ? also pics would be nice
thanks
chuck
BobList
Re: 1998 force tilt and trim problems
make sure circuit breakers are not tripped, I have 2 on my 88 Force 125. if they are ok, it sounds like a voltage supply problem, Once, I had the wiring in the throttle lever rubbed through, but I didn't notice any clicking. it just didn't work, but then again, I was on the water, and engine was running.. noisey. Try working the trim while slowly moving the throttle forward and backwards, that might uncover a problem in the wiring., Now,, some guys say that the motors go up , and you must determine if the clicking is coming from the RELAY or the motor.... a motor will be a heavier "thunk" sound. Then post what you've found.
BobList
Oh, I forgot... find your grounds on the engine, and remove, clean, and retorque them, Same for the battery terminals. That is usually the problem 95% of the time, and if it isn't, you've just eliminated the most likely cause.
jerryjerry05
If it's an 85hp then it's not a 98 maybe a 86-89 not a 98. 90 was made from 90-99??
Pics of your system and motor??
Clicking could be a weak battery,bad solenoid,bad connections,corrosion on the contacts??
