Will a lower unit from a force 1997 75 HP fit on a 1998 75hp force
C catjt98 Recruit Joined Dec 6, 2012 Messages 3 Apr 4, 2016 #1 Will a lower unit from a force 1997 75 HP fit on a 1998 75hp force
HotTommy Lieutenant Junior Grade Joined Mar 15, 2013 Messages 1,025 Apr 4, 2016 #2 There is a good parts listing on a competing website that lists part numbers based on the serial number of the engine. If you can get the serial numbers of the two engines, you may be able to go there to determine if they used the same components.
jerryjerry05 Supreme Mariner Joined May 7, 2008 Messages 18,196 Apr 5, 2016 #3 According to the parts cross overs NO There is a difference somewhere?? Try taking your old and compare to the one you want to replace it with??
