1998 force help
1998 force help
  • Yes
    Votes: 0 0.0%
  • No
    Votes: 0 0.0%
  • Maybe
    Votes: 0 0.0%
  • Total voters
catjt98
Will a lower unit from a force 1997 75 HP fit on a 1998 75hp force
HotTommy
There is a good parts listing on a competing website that lists part numbers based on the serial number of the engine. If you can get the serial numbers of the two engines, you may be able to go there to determine if they used the same components.
jerryjerry05
According to the parts cross overs NO
​There is a difference somewhere??
Try taking your old and compare to the one you want to replace it with??
