1998 force 120 HP Thermostst ?
tomcatcain
Going to change water pump assembly and thermostat before spring,mercury marine list 2 thermostats.130 degree that the service manual calls for,$13.75 .But then they list a OPT,118 degree for $51.05. Whats the difference between these to create the cost difference? Thanks !! :confused:
roscoe
Re: 1998 force 120 HP Thermostst ?
I have no idea why the cost difference.<br />Also no idea why you would want a 118* stat.<br />Force thermostats that I've seen are either 130* or 143*.<br /><br />You can also get an aftermarket thermostat from NAPA for about $9, but it will likely take two trips there to get it, one to order it, one to pick it up.
tomcatcain
Tks Roscoe for yr repley,newby at large hp motors,use to a 15 or 25 hp. Have a 19ft trophy to do some trolling off coast of N.C. now ,trying to take of any problems before they happen.Didn,t know why an opt stat ! THANKS !!!
andy6374
If you plan on doing lots of trolling I would go with the 143* tstat or a set of warmer plugs
Dawg2
Dont know what is right tstat for you but my 1989 85 hp calls for 110 degree tstat it is $32.00 at mercury dealer.......
imported_LakeRunner
Location, location, location. Colder water needs hotter Tstat. Also the lower Tstat is for high performance (racing), thats why it cost more $$$. At least thats what my mechanic tells me!
imported_bjs
my tstat was 130 degree i dont remember having other option's my motor is a 1998 120 it runs fine with the 130 t stat.
