Re: 1998 etech 225 hp evinrude outboard(oil warning system )
If its a 1998 it a Ficht, check the float in oil tank in boat. Did you run it low of oil? If so you may need to reprime system. If it is ok you will need to test the oil pump to see if it is working and the test pressure switch on oil pump.Dont run it untill you get everything tested!!!!
