1998 Chaparral 252 gas shock issues????
chapp252
I am looking for gas shocks for my engine compartment. I have purchased two new ones from a “reputable” dealer online but these shocks only last for a short period of time. Something like a week max.
What weight should a be using? I am currently using 37” long x 40lbs...there was two 30lbs before.
what in the world would cause a gas shock to work great when installed but stop working after a few days?!?
Where should I buy good shocks?
tpenfield
These struts you mean . . . ?
Do you know what was there originally? Maybe they were replaced previously with a lighter strut/spring? 30-40 lbs seems light for an engine cover spring . . . :noidea:
chapp252
Yes, those are the gas lifts I am referring to. I do not know what was original. I am hoping someone here does. 🤞🤞
stop being impatient. patience is a virtue.
the brands that you want for gas springs are along the lines of Suspa, Bahnsbach and ace controls.
gas springs are simply a nitrogen filled air cylinder. what happens over time the seals leak and the nitrogen escapes.
the ones that initially failed would have had a manufacturer and a part number.
However Chaparral is still in business, the original owner is still behind the scenes and the company has a great customer service department. call them, they can either sell you the original style that lasted many many years or they can point you in the right direction.
