1998 5.0 mercruiser no electrical power
bjc8990
My starter would only click when I tried to start it. So I tightened the nut on the solenoid, as I removed the wrench I got a big spark. Now I have no power at the control panel and nothing when I try to start it, I looked for a fuse or breaker on the engine but unable to locate one. any suggestions
alldodge
There is a 90 amp fuse on the battery post which looks like the pic below.
There is a fuse inside
tlewis1
Agree with ALLDodge sounds like you blew the 90 amp fuse. As for your issue before that with the starting it could either be the starter or the slave solenoid on the top of the motor. Grab a multi-meter or 12v test light and confirm where you have power and where you don't. Pretty simple test procedure.
bjc8990
Thanks to both of you
I will check for the fuse and the solenoid
bjc8990
None of my local boat dealers has the 90 amp fuse so I will check ebay
alldodge
I bought mine online, just search for it
Have you verified that the fuse is the issue?
