1998 4.3gl engine replacement with Edelbrock 4B carb
djrevkev
I had to buy a new fuel line when changing over to the 4 barrel. The new fuel line has a threaded 3/8 end on both sides. Fuel pump with old line took a threaded 1/4 end. Anyone on here ever do this and know where I can get a 3/8 female to 1/4 male adaptor for the fuel pump side?? Ive checked online but want to make sure I get the right flare connector. Thanks.
Scott06
Since these double flare fittings are the same as brake lines probably a decent auto parts store would have them or
if you need a 90 at the pump a 1/4” street elbow will do ya.
