1998 350 mag starter solenoid problem.
Bryan Henry
Just get a clicking noise when I try to start. I will start about every 10 turns. Where is the solenoid?? Sounds like its in the box near the air cleaner with the red reset button on it.
Thanks, Bryan
Bt Doctur
Re: 1998 350 mag starter solenoid problem.
that would be correct, called a "slave solenoid"
Bryan Henry
Where is it? Whats it look like? Where do I get the part? Any pics or videos out there on this?
Thanks Doc
Thanks Doc
Ayuh,.... Try the factory Manuals up in the Adults Only section at the top of this forum,....
Nope, No videos....
Bryan Henry
I dont see the Adults only section. Where is it?
Bryan
Bryan
Ayuh,... At the Top of the list that you clicked on to get to this page yer readin'.....
Bryan Henry
OK, found the slave solenoid here locally. Was getting it all back together and I let the red/purple wire touch the edge of the metal box. Sparks flew. Now no power at all. Where is the fuse I blew???????????????
Thanks, Bryan
Don S
Look around on the engine, there should be a circuit breaker with a red button. It's a push to reset circuit breaker.
In the future, disconnect the battery when working on the electrical.
Ayuh,... Could that have blown the Lawyer fuse at the starter,..??
Ya, ALWAYS disconnect the Batteries...
Bryan Henry
OK, I took my volt meter and traced it to the 50 amp reset button. BUT cannot push it hard enough to get it to work. I think its fried. I will replace it now.
Thanks, Bryan
45Auto
There's another solenoid on the starter that is probably where your problem really lies. All the little slave solenoid on top of the engine that you replaced does is energize the starter solenoid that handles the heavy current.
Don S
Thanks, Bryan
Did you have power TO that circuit breaker? If not try checking what bondo calls the "Lawyer Fuse" designed to protect those that don't read manuals or disconnect battery cables.
There is a square fuse on the starter solenoid that may have blown.
Looks like this.
attachment.php
Bryan Henry
OK, I bypassed the red 50amp breaker and she fires right up. I fried the 50amp breaker. Dont see alot of info on people doing that, but thats what is wrong with mine. Found one on Ebay, so got it on the way. Thanks for all the help guys.
Bryan
