1998 25hp 3cyl oil recirculation
Laxininthewood
Recently bought a motor, 98 25hp 3cylinder johnson. Clearly was over heated and melted the oil recirculation hoses and I have no idea where they are supposed to be routed to. Anyone have any in site or help with this? There is 3 brass straight nipples and 4 90° nipples and a plastic T.
boobie
Best to find a factory service manual and it will show you in there.
Faztbullet
Do a search on here for it and my user name as I got a diagram from a retired rep. It was posted it last year for someone in same situation..
Doh
I would remove the Oil Tank and run it 50:1 mixed gas.
The 3 Brass Nipples are for Oil Injecting and can be capped when mixed fuel is used. The 3 Steel Nipples are for the Oil Scavenging from the Crank Case (I would think) In which case I would run a hose between the bottom and top cylinder, then one from the Crankcase to the middle cylinder's nipple.
Bypassing the Oil Warnings are another thing.
NO,No-----The oil was originally mixed in the automatic mixer and went into the carburetors.-----That mixer should be thrown away !!-----Now mix at 50:1 in the fuel tank..-----Do not cap off any nipples but install the recirc hoses !!
Laxininthewood
I need to know how the recirculation hoses need to be routed to.
I have 5 of these motors here you could look at.----Sorry , I am not going to spend time to write a book on how to route them.
You might contact -----mastertech marine-----They offer a " pay for help " om their website.----Seems to say that for $20 they will answer questions.
