1998 / 2008 3.0L manifold/riser compatibility
TBarCYa
I swapped a 1998 3.0L into my 2008 bow rider and have run into an issue with the exhaust. It would appear that the 1998 manifold and the 2008 riser don't quite match up so the question is, will the 2008 manifold fit the 1998 engine OR is there a gasket or conversion to allow using the 2008 riser with the 1998 manifold?
Thanks
achris
More fish than mountain goat
If you post engine serial numbers we can check which parts match up with other parts.
The block and heads should be the same
TBarCYa
Thanks... I'll be ordering the manifold and riser gaskets and hopefully getting this thing ready for the water soon.
