1998 115 hp mariner rough idle
angles4lyfe
Hi i have a 98 inline 4 cyl 115hp mariner, it has a very rough idle and almost always turns off when put in gear. it runs perfect at WOT but struggles to stay on on idle or in idle gear. i went ahead put in new plugs rebuild the carburaters, rebuild the fuel pump put in a new primer bulb, and checked compression which is good. What do you think my problem could be?
jaybirdtx
Re: 1998 115 hp mariner rough idle
Did you check your ignition system @ idle?
angles4lyfe
well i know i have spark on all the cylinder i checked that with a spark tester.
andy6374
When you rebuilt the carbs, did you check that the throttle shutters in carb throats are fully closed at idle. This will surely give you a rough idle if there are open even a bit.<br /><br />What RPM's are you running at idle.
Did you get the carbs back in the same position they were removed from? If not, the linkages between each carb can be off marginally, creating the butterfly fully closed problem Andy mentioned. It would appear you need to do a sync operation to get the linkage set correctly.
angles4lyfe
i did the sync on the carbs perfect, all the throttle shutters are completely closed and yes they are put in the same position i numbered them before even taking them apart. i was thinking it could be the stator or the trigger. what do u guys think?
DHPMARINE
Recheck the spark.A good ignition system will let the spark jump 7/16 of an inch.My guess is at least one cylinder will fail this test.Could be trigger or stator,but usually the switch box.<br /><br />DHP
andy6374
Check the spark as DHP indicated. Loosing a cylinder on those inline 4's is a rough going.
