1997 Mercury 225
TimmyTodd2
I've replaced fuel water separators, cleaned carbs, changed plugs, checked compression, changed the fuel pump and filters, pretty much the entire fuel system. At Lower RPM and idle the engine sputters a little and when in the water will actual die. Starts right back up though. At WOT the engine runs great. Before I start playing around wanted some thoughts. Seems to be rich oil mixture in the exhaust of the of the engine. Any thoughts would be great.
