1997 four winns horn and bilge dont work
mark12
My four winns horrizion that I just bought horn and bilge pump are not working I tried a new horn and a new switch but neither worked so i am wondering if there is a fuse, and where would it be. Thanks wo
Sparkinator
Re: 1997 four winns horn and bilge dont work
Not sure which model Horizon you have, but my 190 Horizon has a fuse panel under the steering console.
Good luck!
Shrike
All factory elecrtical accessories should have fuses.
Always check fuse first.
blifsey
If you don't have one, a small multimeter works great to diagnose problems like this. A set of extra long leads with alligator clips makes it much easier to use if working alone. You could also test the horn and pump by connecting to a known good 12V source.
rwidman
Not if you don't know anything about electricity. :rollseyes:
EDIT: This type of post and the reactions it causes are contributing to the general nastiness we are seeing lately. Please knock it off.
rwidman
Even "non factory" electrical devices should have fuses (or circuit breakers).
Of course you should check the fuse or circuit breaker before replacing a non functional device. We have someone who spent $30 on a horn and $5 on a switch and it still doesn't work because a $.50 fuse is blown! :rolleyes:
rwidman
True...but a great opportunity to learn :)
If you don't know anything about electricity, buying a meter won't help and it's not a "great opportunity to learn".
If you want to learn about electricity, take a course or at least buy and study a book on the subject. Then, the meter might be of some use.
riptide09
The following link will take you to FourWinns previous models site. There you can download the owners manual with wiring diagram. The manual will show you fuse locations and proper amperage fuses. The wiring diagrams will be good for troubleshooting if it not a fuse.
http://www.fourwinns.com/past_product/specs
