RotaryRacer
Thread starter- Joined
- Jul 18, 2004
- 1,361
I have a 1981 Mercruiser (Chevy) Inline-6 165 HP mated to a pre-alpha drive. Not that it matters but these are in/on a 4Winns boat.
I don't have serial numbers in front of me right now.
Is there a fuel filter right in the fuel pump housing attached to the side of the motor? I am pretty sure there is but would like confirmation.
I have a purchased a navman fuel flow transducer, along with a chartplotter. The literature strongly encourages installing a fuel filter before the transducer.
I have temporarily installed one of the cheap ($7) in-line plastic housed filters that you can get at any marine store. The package had a warning on it about only being used on outboard motors. I thought that was a little odd and couldn't really figure out why it would be a problem on an I/O. I have not intention of using this full time. It was simply installed for testing purposes.
On the first outing to test out the fuel computer and some other things I noticed a slight mis at top end that I didn't remeber hearing before. I am concerned that it is running a bit lean due to the additional flow restriction of the filter.
Why are those filters labeled for outboard use only?
Would a good water seperating filter cause any noticeable flow restriction?
Thanks.
Thanks.
