1997 Ficht 150 What is the rev limit ???
bigbass1981
I have a 1997 Evinrude Ficht 150 just wondering what it should be running for RPM. It is on a 1997 19.5 Stratos 295 Pro Elite. Right now it has 24 pitch 3 blade with the jack plate where it is i get right at 5000 -5100 when i was out tonight. Thats with me in it and a friends kid 11 years old not much weight boat fully loaded with gear runs about 65mph or a little more. Any info would help.
Thank You
Derek
Dhadley
Re: What is the rev limit ???
Your theoretical speed is 63 so you must have less than 0% slip. I don't believe I'd change anything. But I think the rev limiter is at 6200 or so. We generally like to see those motors at 5600 or so with an average load.
bigbass1981
Re: 1997 Ficht 150 What is the rev limit ???
Thanks for the info Dhadley. It think it runs great its just that i was not for sure what the rev limit was and where i should target my RPM. The prop that is on it had a few dings but i work as a auto body tech so i took it to work and cleaned them up. I plan on putting a new prop on what does anyone recomand. I have a hydrolic jack plate and i have been just trying to adjust to see what i can gain or loose. Trial and error can be good but i just didnt want to over rev and was wondering what i should target for RPM.
