1997 75hp Power to the prop???
FishH2o
My engine overheated real bad the other day. The alarm was shorted out and we didn't know so by the time i got it shut down the engine was steaming. I took it to my mechanic he put new plugs and a water pump impeller to get it running. Once it ran he noticed it was leaking around the bolts but the motor ran. The leak is very little. He is recommending me rebuild the power-head but the motor still runs.
The motor runs okay until I try to get on top of water. I run it up to 4500 -- 5000 RPMS but I'm not getting power to the prop. It seems like something is slipping however if i just let it ride for about a minute it gets on top of water and hauls *** like nothing ever happened. Does anyone have any idea of what it could be. I don't have the money to rebuild it right now so im trying to make her last a few more months until I can afford it.
FishH2o
Re: 1997 75hp Power to the prop???
Well its on the Exhaust Cover plate side of the motor.
Ayuh,... Welcome Aboard,.... Do a compression test to see where ya stand,...
My guess is ya burnt it up, 'n it's time to rebuild, or replace...
FishH2o
Yeah I have good compression on all 3 cylinders.
FishH2o
I checked the prop out good it's not slipping. Does anyone have any idea what could be slipping? Could over heating cause something in the lower unit to start slipping? I don't have a clue what it could be.
Faztbullet
I would double check that prop as the hot exhaust can melt the hub..also check the compression.
