1997 75hp Charging problem
jcole563
I have a 1997 force 75hp 2stroke motor. I have had to replace the starter on it recently and now the charging unit has stopped working. I have checked all the fuses On the boat and it still doesnt charge. I have heard of stators under the flywheel but I dont think that they are damaged. Does any one know any thing that could possibly help me out I would appreciate it greatly thanks. My email is Jcole563@gmail.com
roscoe
Re: 1997 75hp Charging problem
If the stator had failed, the motor would not run.
Chances are pretty good that the rectifier/regulator has gone bad, or been shorted out.
If the battery cables are reversed - even for a second - it will burn out the diodes inside the rectifier.
The same goes for running the motor without being connected to a battery.
Mercury is charging about $135 for one, don't know if there is an aftermarket alternative for that motor.
