dickjustice
- May 3, 2012
- 10
At the end of last year the engine would not run at wide open throttle so a couple of weeks ago i rebuilt the carb and fuel pump, replaced all the fuel lines and replaced the spark plugs. It ran better than it has in a long time and would even idle for long periods. Yesterday afternoon, after running fine that morning, it began to not want to idle and this morning when i went to crank it would not idle at all. The only way to get it to crank was to open the throttle up but when i pulled it back into neutral it would go dead. I finally got it to go into gear without dieing and it would run at 2500-5000 rpms plus all day long but as soon as got anywhere near neutral it would go dead. The only thing else ive done is add a can of seafoam to the tank but it has run fine since then. Any ideas what could cause this? Also, if i get this problem fixed, how do i increase the idle rpms, before my latest problem it was idling in neutral in the water at 800-900 rpms.
