Basstracer
Thread starter- Joined
- Jun 20, 2008
- 3
Hi all.
I?m new in this forum, and I?ll appreciate any help on this:
My outboard was running OK, but suddenly the oil alarm started to sound, even when oil level is correct. Do I need to empty thre reservoir to check the sensor?, or is there any other possible trouble?
Does this reservoir also have a float inside?
What should I do to verify both of them?
The other issue is: do you recommend to unplug the gas hose every time I finish using the boat, in order to consume the remaining gas in the carburetor?
Does it help the engine in some way for a better start an run next time?
Thanks a lot.
Thanks a lot.
