1996 Yamaha 9.9 Rough at Low Revs
Greggdennhardt
My 9.9 runs excellent at speed; but at low revs it flutters up and down and even dies. Placed in neutral; it dies. Always starts up again but I find I must tweak it up to keep from fluttering or dying when at low revs or neutral. Needless to say, this is a problem when maneuvering slowly in a packed marina or trying to approach a slip. More so since the outboard is a kicker for a sailboat which is a pig at slow speeds anyway. Carb is only a year old. Carb adjustment? Filter? Plugs? All of the above? Any suggestions? Mechanically challenged so expertise much appreciated. Thanks. Gregg
99yam40
Re: 1996 Yamaha 9.9 Rough at Low Revs
Did it run well at idle when you replaced the carb a year ago?
If it did then you need to have carb pulled and cleaned as the pilot jet/passages are plugging up
