NewBoatGuyNH
Thread starter- Joined
- Sep 4, 2022
- 1
I have a 1996 Stingray 556zp that I've had for two seasons. This is my first boat. I got a good deal on it and it seemed to be well maintained. We've really enjoyed it so far. The last time I put it in the water it sounded like someone turned a faucet on in the engine compartment. I took it to the local repair shop and they found a large hole in the gimbal housing. It must have started out small and been leaking for a long time and then just let go. During the time it was leaking it rotted out the transom. I had a new transom and gimbal housing installed and I thought I was good to go. Today I was replacing the piece of carpet covered plywood that the Captain's seat is mounted to because the seat pulled out. I thought it was just this piece of plywood that was rotted. Upon further investigation I find a lot of the floor around where the plywood was mounted is rotted/soft (see first picture). The rotted section is about 18" wide and 36" long. The 4x4 beam that runs side to side at the center of the boat (third picture) appears solid where I can see it. I've read a number of the threads on the forum regarding rot. I'm hoping this is something I can do myself. Here are my questions:
1. Is it practical to think I can just cut out the rotted area and do a repair or do I have to replace the whole floor? Everything else seems very sturdy.
2. What will I find under the wood? Is there something underneath I'll have to replace?
3. Should I anticipate a rotted stringer as well?
4. See second picture - this tube has a 2" section missing. Does this need to be replaced?
Thanks in advance!
Thanks in advance!
