1996 Merc Tiller idle trouble
96Landau
Heres the problem, i can choke it to start and it will run for 5 or so seconds then cuts off and pitttersss out! The gas is clean w/ good oil mix so its not that. It will continue to start if i keep choking it to crank it up. Just wont run for long. Any guesses???:confused:
corm
Re: 1996 Merc Tiller idle trouble
Hi,
If you can keep it running with the choke then the fuel system is the problem.
I would check the carbs for water.
