FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Thanks for your rpley, and sorry about not enough details:
yes I had dropped lower unit for water pump (change pump cover impeller and gaskets)
It was a bit had getting lower unit back on and had to wiggle the shifter back and forth a bit in forward to get the shifter rod (correct name) back in to place.
Prop span in neutral before but I don't recall it being in reverse.
Also I not a grinding clunk when shifted from forward to neutral
It is a 40 HP electric
You're alignment is out on the shift-shaft splines... Drop the leg again and put the shifter in neutral. put the leg in a bench and move the shift shaft until you feel it drop into neutral. refit leg....
I am not so sure- in neutral I can turn prop easy, in forward or reverse I can tell I am turning the drive shaft- but with notor running , in neutral, prop runs in reverse
