1996 larson flyer 166 throttle replacement
Scott V
Hi, looks like the plastic bracket holding my gear cable to the throttle box finally disintegrated when I tried to put it in gear today. It is now stuck in neutral only. I am guessing that that throttle lever is just moving the cable and sheath, not the gear cable in the sheath. This was probable due to the lcables not being free to move inside the sheath. I have figured out what I need to do to free them up. What I am stuck on is how to connect the gear cable to the throttle body. Is there any way to get A replacement bracket for that, or am I going to have to replace the whole throttle body?
Ayuh,..... Welcome Aboard,...... What is the motor,..??
GA_Boater
Welcome aboard.
Getting closer - What is the model number? Or a picture.
