Frangedakis
Thread starter- Joined
- Jun 19, 2010
- 12
the engine runs fine on land can shift into foward and reverse and rev up in nuetral just fine, but when you put it in water it will stall out as soon as you put it into drive. now sometimes after trying to take off and stalling multiple times it will take off and run fine, but when you stop and try to go again same problem stalls out when you try to take off again. I took it to a marine machanic he said it wasnt getting fire in one of the cyclinders and that it needed a new coil pack. he replaced the coil pack and cleaned/tuned the carbs. then told me it was good to go. i took it to the lake yesterday and had the same problem, i dont think he put the engine under a load. before it would also run about 10mph and stay there for a couple seconds and you would feel a jerk and it would take off faster, also when it does take off it has hesitation when you push the throttle. it is getting fuel. the oil bulb is always hard and the fuel bulb is always pumped until hard before starts and they stay hard during operation. the engine will idle 50% of the time in water with no problem the other it just stalls out after a few seconds
