1996 Carbed 175 HP Evinrude V6 fuel question
kencraft69
I purchased this boat at the beginning of this year with the motor above. I took it out a total of 6-7 time and burned about 60 gallons of fuel. My real question is this, the guy i bought it from has always used premium fuel. I know that this engine can use 87 octane but since he has always used 90 i though i should keep using it. For those who know, should i be able to use 87 without any issues? I know they say that using the higher octanes cause more carbon buildup, so i don't know what to do. thanks for the help.
Benny1963
Re: 1996 Carbed 175 HP Evinrude V6 fuel question
87 octane works just as well ,no need for the 93 .
have run 87 /89/93/ and 104.
no big difference ,but im running a crossflow with compression at 105.
if ya had high comp setup you could probaly gain a little from the boost in octane ,the trick is tuneing nd setup.and fresh fuel and filter
dingbat
If all else fails read the manual.
The manual says 87 octane
Dhadley
87 is all that's required if the motor is stock.
kencraft69
I would have read the manual if i would have been given it. This is basically why i was asking the question. My main concern is just that the fuel will not make a difference in the engine if i take and use the 87. Thanks for your responses.
