1996 bravo 3
scott russell
This spring I change the spark plugs and the cap and the rotor fired the unit up seem to run okay maybe a little Miss but when I got it in the water for a test drive it did seem to idle better soon to be running OK until I went to more of a top-end speed and then it a certain RPM it just seems like it wants to just stop running I did not mess with the wires or the coil can someone explain to me or make a suggestion of what it might be
tpenfield
A "bravo 3" is the outdrive (I assume) . . . tell us about the engine. Serial number is best.
thumpar
The engine in front of a B3 could be anything from a 4.3l to a 502. What do you have for an engine? Is it Carbed, EFI, MPI?
Ayuh,.... Welcome Aboard,..... Change the fuel filter, 'n inspect the contents of the old one for stuff other than fresh clean gasoline,.....
