If your battery has a full charge you need to clean up the connections on the battery cables. . .both ends. . .and the solenoid to starter cable. Give special attention to where the battery ground cable bolts onto the engine block.
Ha sometimes the obvious, check your landyard switch maybe its in off position. Happened to me more than once at lake. End of year i put in off position just in case kid turns it over
