1996 75 hp force outboard want start
stephen cooper
hey guys i went to make sure my boat would start and it would not.the starter turns but does not engage, do think the starter is bad.
JB
Re: 1996 75 hp force outboard want start
If your battery has a full charge you need to clean up the connections on the battery cables. . .both ends. . .and the solenoid to starter cable. Give special attention to where the battery ground cable bolts onto the engine block.
199675hpforce
Ha sometimes the obvious, check your landyard switch maybe its in off position. Happened to me more than once at lake. End of year i put in off position just in case kid turns it over
