1996 170 Horizon O/B Dash Module Removal
timalabim
Anyone have the steps to remove the dash on this model? I got the 2 large wing nuts under the dash removed but can't seem to get the dash module itself to budge. Don't want to break anything. I need to pull out to check my gauges. Having a fuel gauge issue. The sender checks out OK but the gauge won't go to full.
timalabim
Re: 1996 170 Horizon O/B Dash Module Removal
Just in case anyone else needs this info, I figured it out. Just 1 screw at the top center of the gauge cluster panel itself. No need to remove the dash at all.
ncdthree
PLEASE shed some light on how you did this. I have a 1996 Horizon 200 and the gauge cluster has developed a film on the inside of the plexiglass lens covering the gauges. Its getting hard to see them.
I already removed the top screw you mentioned...and that thing doesn't seem to budge. Looking at everything from underneath and behind it all doesn't show you much.
Did you just lift the cluster up a little and then pull it toward the steering wheel and out of the dash that way?
Looking forward to your reply. Thanks.
DBreskin
You're responding to a 3 year old thread. I doubt the OP will answer.
