New to the forum so thank you in advance. I have an issue with the oil injection not sending oil to main tank on engine. Emergency switch operates and fills. When the key is turned on the tach shows green for about 8 seconds then immediately to yellow. This has never worked in the 4 years I’ve owned it. Always used emergency switch to putt around. The gauges were inop when I purchased. Recently had them rebuilt and now function correctly, but still no automatic transfer.
