Just bought a 1995 Super 17 Select - interior had been redone .
I haven't put in water yet, re-wiring from scratch.
1st testing and addressing any pump issue.
Transom has the standard bilge plug, and two intakes with pumps on inside.
Assuming one for each live well (front and rear).
I am baffled when trying to figure out how the livewells drain.
It looks as though the rear livewell drains to a T fitting directly above the intake pump...for recirculating ???
The front live well pump only has one hose heading towards the front under the floor.
Each live well has a high level overflow that goes to a port on each side of the boat.
and a small drain hole at the bottom.
I am hoping the front one just doesn't drain to the bottom of the boat and into the bilge.
Can they be draining out the intake pump ????
Tonight I plan on filling one to see what happens.
Strange to me that there is not a drain port on the transom...just the standard plug and the 2 Intake Pump impellers.
thx
thx
