flashback
- Jun 28, 2002
- 4,473
I just posted a question to Rick Stevens in Cedarcove's thread on the same subject but decided to start my own to avoid confusion.
new to me boat so I expected some pit falls. The first was the block drains, they were the little wingnut spigots like they used to put on a radiator in the old days. I broke the wings off and got the entire fittings out of the block and all was good. Come spring I want to mod these drains, with something similar to the manifold drains as they worked well.
I pulled the circulation hose off the engine completely because I found it easier to get the bottom end off the pump by taking the top end off the Tstat. I would like to put a fitting in the bottom of the hose to eliminate this step.
I cut the input water hose just before the steering cooler and plan to put a tee fitting in it..
basically just trying to make the job less of a pain in the butt and would like any tips as to what you folks have done..Thanks.
