1995 OMC Cobra V8 5.0 Ford
acann
Spark plug firing sequence. I see the numbers for the firing sequence but which number goes where?????
Guy I bought the boat from, pulled the plug wires off when he winterized. Should the longest wire be furthest away from the distrubutor and the shortest one closest?
a70eliminator
Re: 1995 OMC Cobra V8 5.0 Ford
Start with number 1 on the distributor cap (about 1 o-clock) follow the order counterclockwise. 1234 left bank and 5678 down the right bank.
acann
got it . now putting the wires on the motor in correct position?????
thx
'95 four winns 195 sundowner
omc 5.0 cobra
Don S
Assuming the distributor is still in it's original position, here is the firing order for your 95 engine.
If the distributor is not installed correctly, you will have to locate #1 TDC on the compression stroke to find out where #1 cylinder is located.
http://forums.iboats.com/showthread.php?t=427081
attachment.php
