1995 Merc 90HP Tracker outboard-- any common problems to look for?
Cady8special
I never owned a merc before and just bought a 1995 90HP Merc Tracker. Are there any common problems I should look for? Anything above and beyond the typical maintenence on a 1988 Johnson 90HP?
Any positive or negative reviews on this motor, or one similar?
B-Dozer
Re: 1995 Merc 90HP Tracker outboard-- any common problems to look for?
Its a outboard motor expect everything to go wrong, hope for less! lol
1nebel0
These motors don't like to idle as they are 3 cylinders so you know why....put it in the water in gear at idle to adjust best idle..The only way you will be satisified and at best will be lumpy but won't die...
