FD3S20BRX7
Thread starter- Joined
- Jun 16, 2016
- 2
Boat is a 1991-1995 Bayliner Trophy 2002WA, my fiancee's dad gave it to me. The boat ran in 2008 before it set up for the past 8 years with no covers on it :facepalm:. From what I can tell, the Force 120hp isn't the original motor that came with this boat, he bought it used as it is now. The Serial # on the transom is to worn from weather to read. From what I've gathered, it's a 1995 Force 120hp. When I received the boat a few months ago, one of the magnents had come off of the flywheel, I epoxied it back on the flywheel using spacers to get it evenly spaced between the other magnets, clamped it on, and let it cure for 72 hours.
I've replaced:
Ignition Switch, it would barely turn from sitting in the weather.
Batteries
Spark Plugs
Switch box - with CDI P/N 114-5772
Trigger - with CDI P/N 134-7029-4
Stator: with CDI P/N 174-9710K 1
Regulator/Rectifier: with CDI P/N 194-5279
The motor had a newer model red stator on it with an adapter kit installed (P/N 834949A2). The new, correct year model, CDI stator bypasses this adapter kit. I've disconnected and connected the kill circuit before and after each part was installed. I ran ohm and DVA test on the stator and trigger. I didn't mind replacing the entire ignition, considering how old it is and I don't want to get stranded. But, I still have no spark. Is it possible that all four ignition packs have gone bad after sitting for so long? The batteries have 12.7 volts on them, but could the starter not be spinning fast enough to get any spark? How are the RPM's and Ignition Spark related? Any other Ideas on what else it could be?
Pictures of Ignition https://goo.gl/photos/8hb2kMq5B4GaBbGKA
At the wiring harness plug under the engine cowl there's a tan and brown/white wire connected together in one picture and a red wire plugged.
I've replaced:
Batteries
Spark Plugs
