1995 Evinrude E90ELEDC fuse location(s)?
fourtwenty
Can anyone tell me where the fuse(s) are located on this motor? Battery is good, but nothing on the motor will work. I went to start it about 30 mins after it ran fine and nothing works. no tilt, trim etc.. I figure it's a fuse but I have no idea where they are located and I can't find any wiring diagrams online. TIA!
Edit: to clarify, the motor doesn't turn over, the solenoid doesn't click, nothing at all.
Edit April 2013: The problem is with the tilt/trim on the controls. When used it shorts out and blows the fuse. I'm trying to figure out how to take the controls apart and replace the faulty switch but I'm not having much luck online finding any diagrams, instructions on how to dissemble and part numbers so I can order a replacement part. Any assistance would be greatly appreciated.
Joe Reeves
Re: 1995 Evinrude E90ELEDC fuse location(s)?
Smaller RED wires leading from the starter solenoid...... one of them contains the power fuse that supplies voltage to the ignition switch.
bob johnson
on the port side of the port head there is a black plastic cover that hides the big red plug and the fuse holder. should be two SS screws holding it onto the head.... you should only need to loosen them, then slide the plastic cover up a little and it should be free... there wires are packed tight underneath, so be carefull reinstalling
actually it looks like the fuse holder is outside that palstic cover....her eis my 1995 115....
I think your motor is a 60 degree looper as well.
bob
fourtwenty
Thanks guys, found it. 20A. I'll replace it and hope that solves my problems.
fourtwenty
Replaced it, it started once and then blew the fuse. The tilt/trim button on the shifter seemed to be acting up so I'm going to start looking for a short there. Can anyone point me to a diagram of the inner workings of the controls?
fourtwenty
Spring is here and it will soon be time to bet the boat in the water.
