Re: 1995 Crestliner ProAm interior overhaul
Try a fish fillet knife for cutting foam, cuts foam like butt'a and you don't have any waste. If you are using the pink/blue foam it might not work too good, that stuff is kind of dense. I'd give it a try before hauling out the table saw and making a pile of super sticky static electric foam particles
I put my deck back together as it was made from the factory with separate panels. One of the beauties of an aluminum boat is being able to take it apart, glass all the deck together and you can't take it apart anymore. You are going to use more vinyl doing separate panels, the vinyl needs to be wrapped around the edge and stapled on the bottom side.
Here's a little story for why separate panels are good. After getting my boat finished I filled up with fuel and was going to take it out the following weekend. Upon taking the cover off I smelled fuel, jacked up the boat and fuel started running out the drain
I had a massive fuel leak in the tank (I didn't find during rebuild
) and if I had glassed all the decks together I would have been skrewed. I removed the deck panel, and a couple other things, and had the tank out in 2 hours.
The only problems I've had with the vinyl and screws were; Don't let the screw spin on the vinyl face (screw & nut) or it can melt the vinyl, I only did 1... If you torque the screws down too snug and have a void in the plywood, it can blow through and/or pucker the vinyl. Add a #10 SS fender washer under the screw and you are back in business.
