1995 9.9hp Force won't idle...
dfrants
anyone know what the initial setting is for the rich/lean adjustment screw on a 1995 9.9hp Force? how many turns out from lightly seated?
flyingscott
1.5 turns from lightly seated will get you started fine tune from there.
jerryjerry05
Then adjust it in the water, motor warm and in gear.
​The rpm's need to be 750-800 in gear.
dfrants
what i'm finding out that no matter what I do or how I adjust the carb she floods out. It will run great one time then the next she floods. I can't seem to get the float/needle to seal when the carb is pressurized by the fuel pump. I've had this carb off and apart 5 or 6 times now. beginning to wonder if someone has mixed parts from different carbs or something.
jerryjerry05
Pics of the carbs insides??
​Pic of the needle and inside the seat.
How are you setting the float??
Take the pump apart and see if the diaphragm is OK??
