IL GLASTRON
Thread starter- Joined
- May 21, 2006
- 28
I have a 1995 Glastron boat with a 1995 Evinrude 88 spl On the back (I guess its the same as the 90hp)<br /><br />Just bought the boat a few weeks ago. When I bought it, it started right up, no issues, ran it once after that and it ran fine (under powered for the boat but it runs good)<br /><br />Then we changed the plugs and some other maintenance items on it (lower lube etc) and went to put it in on sat for a ride. It started for about 5-10 seconds then quit and would not start again.<br /><br />I have 120 lbs in each cylinder (4 cyl)<br />All cylinders are getting gas<br />None of the plugs are getting spark.<br /><br />We put the "original" plugs back in w/ no luck. Is it possible that the plugs I put in did something. The were not champion, but was the DENSO version of the (I assume) correct plug.<br /><br />Everything ran FINE until we changed plugs. Could the wrong plugs blow or short something out. If so what? And where do I start looking? <br /><br />There is a 20 amp fuse in the motor I checked..its good, all fuses in boat are good.. <br /><br />Suggestions?
