1995 4.3 merc
local933
boat stalls under hard acceleration. strts right back up. if you ease into the throttle it will run fine! smells like it is running rich too. shud i rebuild carb?
bruceb58
Re: 1995 4.3 merc
You should see if your accerator pump is working correctly.
bruceb58
Re: 1995 4.3 merc
With the engine NOT running and the choke held open, have someone open the throttle. You should see a healthy stream of gas squirt into the throat of the carb WHILE the throttle is opened.
