Fl_Richard
Thread starter- Joined
- Jan 21, 2005
- 1,428
I've got twin 1995 150 motors that used to have simular temperature readings. I'm trying to get them simular again.
The problem motor has a new water pump housing,& impeller. (As does the good motor.) They have been always saltwater used and rinsed religiously. They look like new. No corrosion anywhere. They both pee a good solid stream of warm water. Water pressure is around 5 psi at idle and slightly under 30 at WOT (5900RPM) on both engines.
One currently shoots to 160 degrees in idle speed zones then drops to under 120 (end of gauge) while on a plane. The other (the one that hasnt changed behavior) Runs 120 in the same idle speed zone and and rarely goes over 150 at anytime; and runs around 120 while on a plane. I dont think I've ever seen it 160. I tested both engines thermostats, they ALL open fully at 165 (IR temp meter pointing thru water). I replaced the caps, thermostats and springs two years ago as preventative maintenance.
BMC has temperature sensors P/N584152 & 584589 at a $100.00 a set!!
Can I test my existing ones?
