Found a fuel leak at the vapor seperator. I knew there was a fuel leak somewhere but could not find it . Today was a beautiful day in So Cal so that I spent some time working on the boat. When I squeeze the primer bulb fuel comes out of the vapor seperater at the gasket. I think it has been like this for sometime now. I plan to replace the (rubber)gasket before using the boat again. Besides leaking fuel would there be other symptoms due to air entering the vapor seperator? I ask because I am curious if this would create a lean condition or sound the fuel restriction alarm or have any other consequence. Thanks in advance for your replies.
